Sort of a Y block question
Posted By Missouri Mike 16 Years Ago
Missouri Mike
Posted 16 Years Ago
Posts: 210, Visits: 1.2K
Hi Guys-
I have a 5 spd for my '55 Customline and was wanting to stick the '55 3spd o/d trans behind a flathead. Anyone know if this is doable??????????????
I've seen adapters to mate early (up to '53 trannys) to y blocks but don't believe I've ever seen an adapter to mount a trans from a y block to a flathead motor.
As always, any help is much appreciated.
Best to the Y guys.
Missouri Mike
I'd rather be lucky than good.................
    but good ain't bad!!
Posted 16 Years Ago
Last Active: 6 hours ago
Posts: 3.6K, Visits: 497.7K
I'm assuming you mean a pre49 flathead with the bell cast with the block? For post 48's, the trans should bolt up.
