Sort of a Y block question
http://forums.y-blocksforever.com/Topic29950.aspx
By Missouri Mike - 16 Years Ago
Hi Guys-
I have a 5 spd for my '55 Customline and was wanting to stick the '55 3spd o/d trans behind a flathead. Anyone know if this is doable??????????????
I've seen adapters to mate early (up to '53 trannys) to y blocks but don't believe I've ever seen an adapter to mount a trans from a y block to a flathead motor.
As always, any help is much appreciated.
Best to the Y guys.
Missouri Mike
By paul2748 - 16 Years Ago
I'm assuming you mean a pre49 flathead with the bell cast with the block? For post 48's, the trans should bolt up.
