Full lenth headers for 292 in a '59 f250
Posted By F250racer 16 Years Ago
F250racer
Posted 16 Years Ago
Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)
Posts: 5, Visits: 44
I'm working on a '59 f250 and finally found a 292 for it. I want to get rid of the goofy cross over pipe so I can run dual exhaust.
I'd like to get full length headers for it but am not sure which ones are good or which ones will fit the truck without hitting anything. I will be leaving it at the stock ride height so should have plenty of clearance there.
Where I live I don't need to pass any kind of emissions or inspections(was told full length headers don't pass smog?), so that won't be a problem.
Posted this over on FTE but wasn't getting any solid answers.
This is my first yblock and really first old American vehicle I've worked on/restored.
thanks
____________________________________________________________________
'59 F-250 Styleside Longbed, 292, 4spd, Rockwell 5.83 dually running gear, custom NP205 overdrive.
"The truck's a Ford and the tractor's green"
yehaabill
Posted 16 Years Ago
Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)
Posts: 426, Visits: 1.4K
Y-Guy Racer:     "Reds" has them and fit is good. You might want to look
                at Mummert's site also.(Lots 0f good info there) Plus try
                the other links from this site....
                                            Bill
Bill
Pelham,Al
55Birdman
Posted 16 Years Ago
Posts: 1.0K, Visits: 4.5K
depending on funds available check with Ford Powertrain. They have great headers. Also Sanderson in SF. Reds is most economical set to buy. They fit well and should give good service.
55Birdman Smile  Hickory NC
mr4speedford
Posted 16 Years Ago
Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)
Posts: 82, Visits: 923
Patriot sells long tubes. I have a pair installed on my 1959 f-100. I bought them through summit racing. You may have to look up the patriot catalog and get the number. I paid $180 for the pair.
1959 and 1960 f-100sAkron OH
Posted 16 Years Ago
Posts: 6.1K, Visits: 442.8K
Stan's Headers have a tri-Y.
MikeLongIsland
Posted 16 Years Ago
Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)
Last Active: 15 Years Ago
Posts: 152, Visits: 440
I used the Patriots and the fit is great, however they don't look like they would last a long time.
Mike
 I'm on a Lowwwww Budget
BFOOTER03
Posted 16 Years Ago
Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)Supercharged (323 reputation)
Posts: 323, Visits: 1.2K
Running Sanderson long tube on the 56 and have had no problems with them.
Warsaw, IN
Nathan Soukup
Posted 16 Years Ago
Supercharged (83 reputation)Supercharged (83 reputation)Supercharged (83 reputation)Supercharged (83 reputation)Supercharged (83 reputation)Supercharged (83 reputation)Supercharged (83 reputation)Supercharged (83 reputation)Supercharged (83 reputation)
Posts: 83, Visits: 339
I like the patriots with the coating.They fit good and seem to run real nice!
55 fairlane gasser 312 /c4, 57 f100 292/c4, 52 mainline gasser 302/t10 4speed
