NEED gas cap
Posted By 55Birdman 16 Years Ago
55Birdman
Posted 16 Years Ago
Posts: 1.0K, Visits: 4.5K
I need a gas cap for my TBird. Mine wont seal the tank. Any cap is good doesnt have to be NOS or show quality.
55Birdman Smile  Hickory NC
Posted 16 Years Ago
Last Active: 5 minutes ago
Posts: 3.7K, Visits: 322.6K
Earl:
I don't know what you mean by not sealing the tank, but a Bird has to have a vented cap.
sundance241
Posted 16 Years Ago
Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)
Posts: 202, Visits: 1.4K
Earl ,   A stock 55 gas tank , takes a special cap , becausr of the number plate bracket ,   and is also vented..............................Sam........................P.S.  ....check is en the mail..!!
56 victoria
55Birdman
Posted 16 Years Ago
John the cap is just on the tank fitting loose and wobbling around. I think it needs to be a bit tighter? It has vibrated off before.
DANIEL TINDER
Posted 16 Years Ago
Posts: 1.7K, Visits: 149.7K
Tricky. Assuming an original cap, you could bend the tangs to make it fit tighter, and/or replace the gasket with a new/thicker one (if it has shrunk/worn thin). But don't lose sight of the fact that the required venting consists merely of two grooves under the gasket. Too much compression on a thick/soft gasket would likely seal them.
6 VOLTS/POS. GRD. NW INDIANA
