NEED gas cap
Home
Keeping The Dream Alive!
Classifieds
http://forums.y-blocksforever.com/Topic27462.aspx
Print Topic
Close Window
By 55Birdman
16 Years Ago
I need a gas cap for my TBird. Mine wont seal the tank. Any cap is good doesnt have to be NOS or show quality.
By Hoosier Hurricane
16 Years Ago
Earl:
I don't know what you mean by not sealing the tank, but a Bird has to have a vented cap.
By sundance241
16 Years Ago
Earl , A stock 55 gas tank , takes a special cap , becausr of the number plate bracket , and is also vented..............................Sam........................P.S. ....check is en the mail..!!
By 55Birdman
16 Years Ago
John the cap is just on the tank fitting loose and wobbling around. I think it needs to be a bit tighter? It has vibrated off before.
By DANIEL TINDER
16 Years Ago
Tricky. Assuming an original cap, you could bend the tangs to make it fit tighter, and/or replace the gasket with a new/thicker one (if it has shrunk/worn thin). But don't lose sight of the fact that the required venting consists merely of two grooves under the gasket. Too much compression on a thick/soft gasket would likely seal them.
