master cylinder
Posted By 2X57SEDAN 17 Years Ago
Posted 17 Years Ago
Tom: A late question on this topic. For a 57 Car on Drums, is the 68 Bronco Master cylinder a dual chamber unit, & available for manual brakes? And when you say the pushrod needs to be adjusted, do you mean cut or a piece welded in?
Posted 17 Years Ago
Tom: thanks for the clarification. Splitting the system on my car would be a good safety idea, plus I want to check out my existing Master, as I suspect based on info from this site, that it may be a power brake unit. The braking effort is very hard..
Posted 17 Years Ago
Posts: 3.7K, Visits: 323.8K
Dennis:
The drum masters that I am familiar with are assembled as follows.  A rubber washer, a check valve, a spring, and the piston assembly.  The check valve allows fluid to flow freely to the brake cylinders when you push the pedal.  When you release the pedal, the return springs on the shoes forces the fluid back to the master.  When the fluid meets the now closed check valve, it unseats the valve from its rubber washer.  The spring re-seats the check valve when line pressure drops to about 10 psi.  Is this not a residial valve?
Y block Billy
Posted 17 Years Ago
Posts: 1.6K, Visits: 5.2K
I think there is some confusion between residual valves and proportioning valves going on here. another thing to remember is that the front line of the master is for the rear brakes and the rear outlet of the master for the front brakes. How many people get this mixed up when doing conversions?
55 Vicky & customline
Big6ft6
Posted 15 Years Ago
Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)
Posts: 241, Visits: 347
So I'm thinking about upgrading to a dual resevoir, and I'm trying to predict in advance which master cylinder option creates the "path of least resistance" when dealing with a 4-drum car.  It seems like the 68 Bronco MC might be the fastest way to go and the fitting sizes on the Bronco MC are the same as the fittings and lines already used on my 56 customline ( can anyone comfirm this?)
Also, what is the pain associated with a MC that has the line outlets on the fender side of the MC?  I can't quite picture my engine bay well enought to understand what hassle this will cuase versus having the line outlets towards the engine side?
I'm hoping to order this today so it comes in tomorrow and I can work on it over the weekend.
Thanks!
Nate - Madison, Wisconsin
56 Ford Customline Sedan
drof75
Posted 15 Years Ago
Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)
Posts: 35, Visits: 248
I used a manual master cylinder for a 67 mustang on my 57 fairlane. Bolted right up. The rod from the pedal had to be lengthened 1 1/2 inches. I think there are adjustable rods available. Then replumb the lines. You will get rid of the tee and run the front/rear lines separate to the m/c. A good place for info on these mods is http://www.57fordsforever.com
Buz
Buz Mills
Dallas, TX
