Posts: 3.0K,
Visits: 8.7K
Has anybody got an automatic flywheel or flex plate they wanna sell?
Visits: 322.6K
Frank: I know your intended application, and I will add that you need the '58 and later flywheel with the starter ring on it. The earlier models had the ring gear on the converter. You can't readily do wnat you want with the early setup.
Posts: 1.4K,
Visits: 7.5K
Frank, I can fix you up. Send me a PM or call 334-227-3004.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Visits: 3.7K
Frank , I have a flywheel that you can have . Do you want me to send it COD ????? Shouldn't cost much more than 5 or 6 HUNDRED . Lon
yblocksdownunder
Posts: 1.8K,
Visits: 11.4K
LON, dont forget registration and insurance??? lon, i have a trunk lock spacer for you. aussiebill.
Posts: 3.0K,
Visits: 8.7K
LON (4/5/2009)
Frank , I have a flywheel that you can have . Do you want me to send it COD ????? Shouldn't cost much more than 5 or 6 HUNDRED . Lon Lon, Aussie flywheels probably turn backwards!
Visits: 3.7K
Bill , Good news on the spacer . Could you post it to me please ,and let me know how much . Lon PS . Frank , are you sure it's the flywheel that's backwards ???
yblocksdownunder
Posts: 1.4K,
Visits: 7.5K
Frank got your message, but can't reply back to you, your mail box is full. Just let me know if you need it. I'll be home from work WED about 18:30, If you are around exit 151 give me a holler.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Posts: 3.0K,
Visits: 8.7K
Glen, Got your call, but when I returned it I had no clue as to how to follow the instructions.
