I know your intended application, and I will add that you need the '58 and later flywheel with the starter ring on it. The earlier models had the ring gear on the converter. You can't readily do wnat you want with the early setup.
I have a flywheel that you can have . Do you want me to send it COD ?????
Shouldn't cost much more than 5 or 6 HUNDRED .
Lon
Lon, Aussie flywheels probably turn backwards!
Good news on the spacer . Could you post it to me please ,and let me know how much .
PS . Frank , are you sure it's the flywheel that's backwards ???
