Project is coming along nicely, been having good luck finding stuff we need. I know it'd be quicker to buy all this at once from a manufacturer/supplier but I am finding some good deals buying stuff individually...Just got a brand new set of NOS Federal Mogul main bearings from this guy...
Tinkers Motor Supply (214) 688-1067
He said he had a number of Y-Block bearings on hand.
Anyhow here is a list of things we still need:
cam bearings
std. con rod bearings
292 piston rings std.
water pump rebuild kit - bought a reman
oil pump rebuild kit
dist. rebuild (cap, rotor, points, condensor etc.) - pending
carb rebuild kit (Autolite ???) 2bbl
head bolts - got 'em
dist holdown - got 'em
gasket kit - have pieced together most everything, need to double check
pulley for crank, fan and fan (engine has no power accesories)
fuel pump and eccentric - pending
Thanks!
