ALANB
Last Active: 15 Years Ago
Visits: 70
My 56 F-100 is just a streetRod!! But after 30 years in the business, I don't think I ever met a set of Headers that didn't "LEAK" or burn your arms under the hood!!! My F-100 with a 312 has the original manifolds with one side reversed and I get along fine with them, (duel's of course)
Your comments welcome .....
ALAN B.
mctim64
Posts: 2.4K,
Visits: 5.0K
Have you ever thought of a set of "Ram Horns" They look nice and should give you no leak problems. You can find old OEM ones on eBay or buy new ropos from Mummert.
ALANB
Visits: 70
"SUPREME"; Are they cast Iron or? ... The Y- Block site is new to me, I was introduced just last week by "Yellow Brick Charlie". Would I actually gain, with headers or just show? As I said, I have duals with reversed manifold's ...Hope to get some answers on my entry, Easy to use/fit/whatever, regarding Toyota P/S on my F-100 .....
ALAN B .
Visits: 442.8K
The rams horn manifolds are cast iron. I suspect that the ones from Mummert are better in the flow department than a stock rams horn. But don't take my word for it. Give him a call. Headers should enhance the performance. For your street driven streetrod, Tri-y's from Stan's headers may be a good choice. I would be using the tri-Y's if only they fit 61-64. All of the other tube designs are quite similar. I doubt there's much performance difference between them.
bird55
Posts: 1.1K,
Visits: 58.8K
I have Stan's headers too. The name of his company is is FPT (FORD Power Train). He makes a quality product. My headers are for the tbird, but he makes them for your app. too, as Charlie said. AND HIS DO NOT LEAK.
Visits: 442.8K
This is a different Stan. http://www.stans-headers.com/And here's a link to Ford Powertrain http://fordpowertrain.com/FPAindex/FPA%20index1.htmFord powertrain, as of1.5 years ago, do not produce headers for a truck. That could have changed by now. When I talked with them they said they made truck headers in the past. There wasn't enough demand so they stopped. Somewhere along the way the tooling was lost.
BFOOTER03
Visits: 1.2K
Alan, I bought just a regular set of long headers from Mid Fifty last year and they worked fine on my 56. Did have a slight clearance issue on the passanger side but no other issues. http://www.youtube.com/watch?v=CrolMJah6tI
Warsaw, IN
56 effie
Visits: 528
Sacramento Vintage Ford sell headers but I am not sure what make they are. I have used them for quite a few parts and have found them extremely helpfull. http://www.vintageford.com/
Hang loose and enjoy the ride. Brisbane Australia
bird55
Posts: 1.1K,
Visits: 58.8K
charliemccraney (12/15/2008)
This is a different Stan. http://www.stans-headers.com/And here's a link to Ford Powertrain http://fordpowertrain.com/FPAindex/FPA%20index1.htmFord powertrain, as of1.5 years ago, do not produce headers for a truck. That could have changed by now. When I talked with them they said the made truck headers in the past. There wasn't enough demand so they stopped. Somewhere along the way the tooling was lost. Thanks for straightning me out on that Charlie. And good to know of another header source. I've always "needed" a 57-64 ford pickup.  BFFOOTER, your 56 pickup looks AND sounds great, i caught it on UTUBE.
BFOOTER03
Visits: 1.2K
Alan, apprecaite the kind words hopefully it will even sound better in the fall and kudos to you for spelling Alan the correct way!
Warsaw, IN
