Visits: 268
Did any y blocks come with a clutch fan 1 car i got has 1 on it
86 mustang 351clt250/500r hybrid 4'' over swinger scr porting v2 reeds Q-pipe West virgina
Visits: 6.1K
Hey Itman; Put clutch fan assembly on my 55' Bird. Have had great luck, runs cooler even in 4th of July parade. Got it at Casco. Also you should use the aftermarket schroud. Hope this helps God Bless Eddie
EddieLake Forest, Ca. 92630
Visits: 1.0K
Eddie Paskey (10/21/2008) Hey Itman; Put clutch fan assembly on my 55' Bird. Have had great luck, runs cooler even in 4th of July parade. Got it at Casco. Also you should use the aftermarket schroud. Hope this helps God Bless EddieWhere do you find an aftermarket shroud? And where did you find a clutch fan? What was it off of?
E.J. in Havana FL
Visits: 6.1K
Fan Clutch and Fan came from Casco, you might also consider the small water pump pulley from Consours. My car runs at about 180 to 190 even on hot days and in parades, (4th of July). Hope this helps. God Bless Eddie
Visits: 6.1K
Forgot to tell you that Casco has the schrouds too!!! Eddie
Visits: 154.2K
Has anyone ever studied the comparable parasitic loses of "clutch" vs. "flex" fans? No clutch to fail with a flex fan, and initial costs should be less?
6 VOLTS/POS. GRD. NW INDIANA
