Clutch fan
http://forums.y-blocksforever.com/Topic17743.aspx
By ltman - 17 Years Ago
Did any y blocks come with a clutch fan 1 car i got has 1 on it
By Eddie Paskey - 17 Years Ago
Hey Itman;  Put clutch fan assembly on my 55' Bird.  Have had great luck, runs cooler even in 4th of July  parade.  Got it at Casco.  Also you should use the aftermarket schroud.  Hope this helps    God Bless    Eddie
By ejstith - 17 Years Ago
Eddie Paskey (10/21/2008)
Where do you find an aftermarket shroud? And where did you find a clutch fan? What was it off of?
Fan Clutch and Fan came from Casco, you might also consider the small water pump pulley from Consours.  My car runs at about 180 to 190  even on hot days and in parades, (4th of July).  Hope this helps.  God Bless    Eddie
Forgot to tell you that Casco has the schrouds too!!!     Eddie
By DANIEL TINDER - 16 Years Ago
Has anyone ever studied the comparable parasitic loses of "clutch" vs. "flex" fans? No clutch to fail with a flex fan, and initial costs should be less?
