Last Active: 10 minutes ago
Posts: 1.8K,
Visits: 154.6K
Y-Block book instructs to flood & then turn the gears, but with the motor on a stand upside down, it looks like the oil would just run out. I'm wondering if only lubing the gears would be enough, since I plan to throughly prime the engine with a drill before first start regardless (?). I certainly would like to avoid turning the motor over to install the pump.
6 VOLTS/POS. GRD. NW INDIANA
Posts: 2.0K,
Visits: 306.6K
Visits: 7.8K
Make sure the gears are nice and oiled. Then prime the motor with the drill as you were planning. The oil that's on the gears should seal enough to create a suction that should pull oil from the pick up.
Posts: 1.8K,
Visits: 154.6K
Big Tim (7/13/2026)
Make sure the gears are nice and oiled. Then prime the motor with the drill as you were planning. The oil that's on the gears should seal enough to create a suction that should pull oil from the pick up. I was thinking of using the 50/50 mix of oil & STP I have prepped for assembling the valve train, since would be less likely to run out and make a mess before I actually get the pump installed.
Posts: 1.4K,
Visits: 2.0K
If you're using STP (unless the formula has changed over the years), I hope you're working in a clean, dust-free environment. The stuff is sticky.
Posts: 2.0K,
Visits: 306.6K
Just wondering, are you going to use this mixture for cam lobes and followers break-in also?
Posts: 1.8K,
Visits: 154.6K
KULTULZ (7/13/2026)
Just wondering, are you going to use this mixture for cam lobes and followers break-in also? No, just pushrod ends, rocker tips/shafts, etc.
Posts: 2.0K,
Visits: 306.6K
Posts: 1.8K,
Visits: 154.6K
I usually take seller’s product recommendations with a grain of sand. I had to laugh though, when they talk about their lube’s ‘stickability’. Nothing sticks like STP. The damn stuff is nearly impossible to clean off 😁!
Posts: 2.0K,
Visits: 306.6K
No, the reference was meant to describe using ASSEMBLY LUBE in the engine before first fire. STP is (was) a quick can of compression and/or low oil pressure correction.
