mongo
Posted 6 Months Ago
Last Active: 6 Months Ago
Visits: 559
Are new Mushroom lifters flat or convex ? Work with some of these high tec coatings , wondering could this be another upgrade ?
Po ol DavieSparta , Tn.
The tappet faces are convex, not flat.
mongo
Visits: 559
Perfect Ted, I knew you would know ! Have you tried any of the lifter coatings , as I see on NASCAR valve train parts . Most cams are not coated , any of the newer solid lifters , after periods of high rpms , show no wear at all either . Next time in Mooresville ,NC , I may take set , and have coated .
Litshoot
Visits: 702
Mongo are you talking about dlc type coatings, or additive like cerakote slick coatings. went to school in mooresville and missed access to a lot of cool tricks now that i actually am able to afford some of them. i had a classmate most of a carbon fiber go cart at the shop he worked at. Seth
Posts: 3.8K,
Visits: 33.2K
The Reason they are convex is so they will rotate on Cam Lobe as the Engine is running. No rotation will wear out Lifters in very quick order.
Posts: 1.4K,
Visits: 2.0K
mongo (4/13/2026)
Are new Mushroom lifters flat or convex ? Work with some of these high tec coatings , wondering could this be another upgrade ? The Topline Hylift Johnson Y-block lifters, which are sold by Isky, Clay Smith, etc., and can be purchased directly from Topline, have a temporary protective coating that prevents accelerated wear during break-in.
slick56
Visits: 4.5K
Do you know what radius they are Ted?
South Australia
Cliff
Visits: 13.9K
The only lifters that do not wear are Trend Tool Steel lifters, however they are not made any more. I bought all that they had left.
slick56 (4/22/2026) Do you know what radius they are Ted?Should be 50-52”radius.
slick56
Visits: 4.5K
Thank you Ted.
South Australia
