Posts: 3.8K,
Visits: 33.2K
I am pulling Engine leaving Fordomatic in place. How many Bolts are used to bolt Bell Housing to Engine? I took 2 out at Bottom. Looks like 3 at the top Area. Is that it. Hard to tell without climbing on top of Engine. Thanks!
Visits: 323.8K
Yes, four bolts is correct. Sheet metal pan at the bottom of the bellhousing has to come off, also the starter.
Posts: 3.8K,
Visits: 33.2K
OK. Thanks John. Bottom done. Starter and Tin off. 2 Bolts taken out. Ready to finish and pull Engine. Wasn't sure how many more Bolts. Getting too Old to be climbing on Engine to have a look. This will be My second Y-block rebuild. Just a stock redo from top to bottom on an original untouched 292. What I learned on the first One 10 Years ago, right and wrong, will benefit this One.
Visits: 323.8K
Mark, I forgot to remind you to be sure to unbolt the torque converter from the flywheel if you want to leave the converter with the transmission when you pull the engine. A '55 should have six bolts, two groups of three, 180 degrees apart.
Posts: 3.8K,
Visits: 33.2K
Done it. Mine has the replacement Flex Plate which uses 4 Bolts instead of 6. I lost One after I had the Engine out to re-seal it about 5 Years ago. Guess I forgot to tighten One and I found it disappeared when I went to unbolt Flex Plate. I guess I will have to improvise and make One. Nobody in my neck of the woods north of the Border has One. Don't need it for awhile yet. Thanks!
Posts: 1.4K,
Visits: 2.0K
NPD has a photo in their catalog and the part number is T-6379-2A (6 required). No price, says to call. Florida: 800-874-7595 North Carolina: 800 368-6451 Michigan: 800 521-6104
