Check Timing chain 55 TBird
Posted By RossL Last Year
pintoplumber
Posted 8 Months Ago
Posts: 1.0K, Visits: 164.4K
55blacktie (1/14/2026)
Interesting. I hadn't seen the pilot tool before or the 239 crankshaft spacer. Not being familiar with the 239, why does it use a crankshaft spacer?
The 239 doesn’t have a damper, just a pulley.
Posted 8 Months Ago
Posts: 3.7K, Visits: 498.2K
make one out of wood.
FORD DEARBORN
Posted 8 Months Ago
Posts: 840, Visits: 113.5K
Here's a very simple alignment tool made from a piece of aluminum if you have orhttp://forums.y-blocksforever.com/uploads/images/09a27235-8bf5-4070-bee9-bc57.jpg know someone who has a lathe. The screws serve as means to extract the tool. Hardest part was filing the key slot.
Posted 8 Months Ago
Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)
Posts: 2.0K, Visits: 306.5K
I think what is going on is the adapter was used only on the 1954 239 CI PASS CAR ENGINE (EBU) and the ILL shows only on factory PS.
http://forums.y-blocksforever.com/uploads/images/b330435a-25a7-46ad-813a-1a10.png
Do you see how much shorter the pulley (6312) w/o PS snout is as compared to the pulley (6312) w/ PS snout?
http://forums.y-blocksforever.com/uploads/images/91c7d66f-d0cc-4a43-b38a-dd9a.png
http://forums.y-blocksforever.com/uploads/images/348c56a1-f393-424f-8a14-9997.png
http://forums.y-blocksforever.com/uploads/images/37e89384-8e4a-4665-9025-2eeb.png
Cataloging is fragmented on earlier applications and one would need a year correct MPC to actually pin it all down.
TED will correct me if I am wrong..
Posted 8 Months Ago
pintoplumber -
http://forums.y-blocksforever.com/uploads/images/80c0fc3f-da67-4827-99fa-840.jpeg
You are showing a 1954 239CI FORD PASS CAR engine w/o PS?
pintoplumber
Posted 8 Months Ago
This is a 239 car engine that was in my truck when I bought it in 1978. I have another 239 car engine in the garage. Both have the short pulley, however one is stamped steel and the other one is cast steel or iron.
Posted 8 Months Ago
THANX!!! for the reply.
Both are pass car engines (1954 EBU), short pulleys but are different material?
That is interesting.
Posted 8 Months Ago
Going out on a limb here, but it seems to me that unless the engine is pointing up no spacer is going to do the job right because the cover will push down the rubber seal at the top.  If the bottom of the cover is even with the pan rail of the block then you are covered.
RossL
Posted 8 Months Ago
Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)
Posts: 150, Visits: 7.3K
paul2748 (1/16/2026)
This is what I am going with "If the bottom of the cover is even with the pan rail of the block then you are covered"................................................
1946international
Posted 8 Months Ago
Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)Supercharged (266 reputation)
Last Active: 6 days ago
Posts: 107, Visits: 21.5K
Remember to align the front cover so it is centered with the crankshaft at the seal area. A while ago I assembled a 292 motor and did not do this and the seal leaked. I think there is a tool that goes around the crank snout so the cover will be centered while you tighten the cover bolts. Like 55blacktie said, people don't like buying tools that will not get much use, and that sounds like me so I made the tool. You may be able to just eyeball the alignment.
Sorry, I did not see that someone already said something about this....
