Check Timing chain 55 TBird
Posted By RossL Last Year
Although I make a conscious effort to watch my language when around people, if this happened to me while alone, working in the garage, I would, to quote Kramer, "Let the expletives fly."
RossL
Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)Supercharged (402 reputation)
Posts: 150, Visits: 7.3K
After trying a few options, I decided to use an Oscillating Multi Tool with a Carbide Blade to cut the steel block.   It was about the only thing that would fit into the pulley.  After about 15 minutes this is what I have
http://forums.y-blocksforever.com/uploads/images/d85a6a16-87e6-44b8-aa53-e150.jpg
I hope you already had the oscillating tool. considering your success (I was expecting the worst), maybe that's something I need to add to my toolbox.
Is Hill's going to refund your money for the puller?
RossL
55blacktie (12/19/2025)
 I already had the tool.  Cheap version from Walmart.  I bought to cut wood, never considered it for this job until I saw the blades in Home Depot.  3 carbide blades were $43.   The vendor that sold me the puller said he would refund and send back to Hills
I thought the oscillator looked like something from Harbor Tool. If I were a professional mechanic, I would look elsewhere for tools, but okay for something that's not used often. I've never had a problem returning defective tools. I bet those 3 blades cost more than the tool.
Let us know how the other puller works out.
RossL
New puller arrived.  Besides the swivel end the threaded rod looks like it's about 1/16" thicker.  I have to check the threads in the crank before I move forward.   I bough a 6" 9/16 18 bolt to test the threads, easier to manage with a longer bolts to thread it straight in.  I will use the stock bolt when I install and use the puller
http://forums.y-blocksforever.com/uploads/images/af9fb974-e5ca-4607-8ffd-c58a.jpg
The new puller looks stouter to me as well.
Posts: 4.6K, Visits: 39.3K
I've used a lot of HF tools in my home garage. As a hobbyist I find the satisfactory. For a day to day operation I would definitely go for brand names. Hope you find a way to get that damper off soon. Are you soaking it with penetrating oil?
RossL
The Casco tool made the difference.  I talked to someone that uses the Hill's version, but he welded a small plate to the end of the threaded rod that would contact the crank bolt.  I expected once it started moving it would pop off quickly, but coming off was a slow steady process.  I used an impact wrench for the entire removal to keep the crank from moving and to save my back from leaning over the fender turning the wrench by hand
I am going to buy the metal sleeve to repair the snout, it's not that bad, but why chance it.   The rubber looks OK to me.  Any opinions?
Big relief...................... until I realized I am not even half way to completing this job.   I bought the installation tool I can't deal with another setback
http://forums.y-blocksforever.com/uploads/images/d8bcf7ed-d75d-4dbe-a10a-6176.jpg
Just my opinion, but there might be things going on that you can't see. If you send it out to Damper Doctor/Damper Dudes to be rebuilt, it should never have to be done again.
