Visits: 1.5K
I don't understand how it can overflow without a coolant recovery bottle? Theres nothing but the cap.
Posts: 2.0K,
Visits: 306.6K
It will have an overflow, but not a coolant recovery bottle. Is that what you are saying?
Visits: 1.5K
I'll bet. Question... Tnis radiator doesn't have an overflow container. What happens when the engine shuts off and antifreeze is hot?
Posts: 1.4K,
Visits: 2.0K
If you take your radiator to a garage, not a radiator shop, they'll send it out to a radiator shop. You'll probably end up paying more than if you were to take it to a radiator shop yourself.
Visits: 1.5K
I would like to keep the original radiator if its salvagable. I was just curious what was available in the event that it was shot. Still looking for a shop. No radiator only shop around here so I guess I'll have to find a garage that does radiators too or travel an hour or so to tucson
Posts: 2.0K,
Visits: 306.6K
I would think you would want to save the radiator. See if this helps finding a competent shop in your area - https://www.bbb.org/us/az/cochise/category/radiator-repairIf you go CAPA or a low quality off-shore radiator (if available), it may not work out well. A custom ALUM RAD is going to be $$$. At the worst, they should be able to re-core keeping the original tanks and bracing. No having to fit/modify to the core support. POSSIBLY - https://www.thebrassworks.net/products/lincoln-radiators
Posts: 1.4K,
Visits: 2.0K
Someone on Facebook suggested Johnson's Radiator in Alabama.
Visits: 1.5K
Not finding a radiator shop near me. If I decide to get a new one, does anyone know where to look? I did google search for one but didnt find any. Doesnt need to be oem,
Posts: 1.4K,
Visits: 2.0K
I agree with Paul & Miker; the same applies to the heater core. My original heater core looked great, but I submerged it in a bucket of water, put my thumb over one tube while blowing into the other to check for bubbles. I wasn't confident with the results, so I took it to a local radiator shop to be tested; it leaked; the shop owner (Randy) showed me damage that I had overlooked. I asked about re-coring it, but Randy said that I could probably buy a new one for less than the cost of re-coring it. He was right. Better still, he didn't charge for the test ($20) because he couldn't make change. I will return to the shop to have mounting brackets soldered to my new radiator (I like the way that they do business).
Posts: 1.9K,
Visits: 195.0K
Brad, given your location and the fact you’ve got factory air if at all possible I’d run that past a radiators shop for a full test and maybe a rodding out. You’re going to need all cooling you can get. Those early Lincoln’s were good that way new.
