Posts: 2.0K,
Visits: 306.6K
It will have an overflow, but not a coolant recovery bottle. Is that what you are saying?
B-rad
Visits: 1.5K
I don't understand how it can overflow without a coolant recovery bottle? Theres nothing but the cap.
Posts: 2.0K,
Visits: 306.6K
The top tank fill neck should have a tube running from it down the side of the radiator (pre-coolant recovery w/ outside container). When coolant expands (overfilled and hot), the cap releases the pressure and the coolant is released through that tube. When the internal pressure subsides to cap rated pressure the cap will close gain.
Posts: 1.9K,
Visits: 195.0K
Brad, I don’t know if you’re a member on the HAMB, but I know there’s a member or 2 over there that’s from or close to Sierra Vista. Be worth a post with that in the title for a radiator shop. If you’re not a member, I’ll ask for you.
B-rad
Visits: 1.5K
Yeah Mike, I am a member. I'll check in with them. So what Kultulz is saying, would I be able to install a overflow reservoir to keep from losing antifreeze?
Visits: 498.2K
Are you overfilling the radiator? The level should be just a little over the core. Check with Speedeway, Jegs and Summit - they have coolant overflow tanks. Usually not a big deal to install one.. I like this type, use it it two of my cars. Other styles available - google coolant overflow tanks  B-rad (10/3/2025)
B-rad
Visits: 1.5K
No. My radiator isn't even installed yet, just wondering if a reservoir would be needed. My buddy has a 50 scruby with a newer engine in it and he changed his overglow out for a bigger one. I wondered why a 54 doesn't have one and if losing antifreeze is something to worry about.
Deyomatic
Visits: 2.6K
Mooneyes has some, too, but they call them "water recovery tanks."
Visits: 498.2K
I've had two different scenerios re coolant. My 48 (modified 302) was losing coolant so I, used the one I pictured and solved the problem. My 54 (modified 312) was not losing any but decided to add the recovery tank based on the 48 situation as a precaution. Advice - get the car together and running to see how everything works Then go to the recovery tank if there is a problem. B-rad (10/4/2025)
Deyomatic
Visits: 2.6K
Paul has great advice. My move is to acquire parts thinking I'll need them and then never use them. Thing is, I never learn.
