Speedo 55 ford
Posted By montana ford man Last Year
montana ford man
Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)
Posts: 167, Visits: 23.9K
The speedometer in my 55 has the needle bottomed out at about 7 mph. I drove my car for the first time after finally getting on the road. What do I need to do to fix it without damaging anything? I’ve thought about trying to bend the needle but I hope there’s a better way to fix it the right way. Has anyone ever had this problem and how did you fix it?
Daniel Jessup
Posts: 2.0K, Visits: 131.2K
Remove the entire assembly and inspect it. I have some information on my website, HotRodReverend.com. Too many photos and videos to post here.
Here is a link to get you started.
https://www.hotrodreverend.com/post/2018/07/14/1955-ford-part-56-speedometer-and-odometer-reset
Daniel Jessup
Lancaster, California
montana ford man
Thanks Dan for the info, I forgot about you and the great articles you wrote on rebuilding your 55.i had the speedometer out before I painted everything but forgot to fix that needle. I will take the assembly out this winter when I have the time. I did put in a different cable after cleaning and lubricating and it works great even though the needle is on about 8 miles an hour when stopped. Thanks again ,the pictures are very good .
Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)
Posts: 2.0K, Visits: 306.5K
SPEEDO REPAIR - https://www.speedoservice.com/
Posts: 3.7K, Visits: 498.2K
How are the readings otherwise?  Is it fairly accurate at different speeds.  You can check it with a GPS.  There are small GPS speedos that you can test it with.  Look on ebay.
montana ford man
Posted 7 Months Ago
I took my speedometer out and found the needle had moved so it wouldn’t drop to zero. I carefully held the part that spins and pushed it down to zero.  On the bench I put my electric drill on it and it seems to work properly. I will know for sure when summertime comes. I have another 55 speedometer that doesn’t work because the spring is stretched out. I’m wondering where I can get another spring ,maybe use a clock spring.
