Speedo 55 ford
http://forums.y-blocksforever.com/Topic169222.aspx
By montana ford man - Last Year
The speedometer in my 55 has the needle bottomed out at about 7 mph. I drove my car for the first time after finally getting on the road. What do I need to do to fix it without damaging anything? I’ve thought about trying to bend the needle but I hope there’s a better way to fix it the right way. Has anyone ever had this problem and how did you fix it?
By Daniel Jessup - Last Year
Remove the entire assembly and inspect it. I have some information on my website, HotRodReverend.com. Too many photos and videos to post here.
Here is a link to get you started.
https://www.hotrodreverend.com/post/2018/07/14/1955-ford-part-56-speedometer-and-odometer-reset
Thanks Dan for the info, I forgot about you and the great articles you wrote on rebuilding your 55.i had the speedometer out before I painted everything but forgot to fix that needle. I will take the assembly out this winter when I have the time. I did put in a different cable after cleaning and lubricating and it works great even though the needle is on about 8 miles an hour when stopped. Thanks again ,the pictures are very good .
By KULTULZ - Last Year
SPEEDO REPAIR - https://www.speedoservice.com/
By paul2748 - Last Year
How are the readings otherwise?  Is it fairly accurate at different speeds.  You can check it with a GPS.  There are small GPS speedos that you can test it with.  Look on ebay.
By montana ford man - 7 Months Ago
I took my speedometer out and found the needle had moved so it wouldn’t drop to zero. I carefully held the part that spins and pushed it down to zero.  On the bench I put my electric drill on it and it seems to work properly. I will know for sure when summertime comes. I have another 55 speedometer that doesn’t work because the spring is stretched out. I’m wondering where I can get another spring ,maybe use a clock spring.
