Visits: 21.5K
Does anyone have a source for shaft bushing for Y block distributors? The later ones with the hinged advance plate. Thanks
Posts: 1.8K,
Visits: 306.4K
Can you post the DIST ID NO found on the bowl to make sure you get the correct one? The one shown below is a rebuild and had the ID NOS taken off (one fits all ... ) but will give you an idea where to find them.
Visits: 21.5K
Stamped in is COAE and at another place is CBE the cast in number is 2127 with an A stamped in behind it. Thanks for the help
Posts: 1.8K,
Visits: 306.4K
Could the DIST ASSY ID NO (STAMPING) be C0AF-12127-A? If so, the upper busing is B8QH 12120-A and is available repro here - https://www.npdlink.com/product/distributor-housing-upper-bushing/213170
Visits: 497.9K
Here is a couple of names that may have what you want., Both restore ford distributors Lee Johnson 812-598-8965 Lou Sumas 440-439-5628 A long shot, but there is a company that sells distrubutor gears - Distributorgears.com - maybe they can help CASCO sells bushings, but they are for TBird disributors. Maybe they will work ? They have ones for the 55/56 units as well as the 57 units. Might be the same as the later units
Visits: 21.5K
KULTULZ , yes it loos like you are right. that may be an F and also it could be a 1 before the 2. So does it look like this distributor has only one bushing?
Last Active: 4 hours ago
Visits: 119.6K
Hello As I remember few Tbirds vendors sold them. Problem is burnishing after installation, I think it requires a special size reamer for final fit.
Posts: 1.3K,
Visits: 1.9K
If you haven't already disassembled your distributor, it might be best left to a professional. Someone on another forum attempted to disassemble his and ended up breaking the distributor housing. As far as bushings go, I'm not aware of any OEM Y-block distributor having more than one bushing. There is a company (don't remember the name) that will add a second bushing during the rebuild, but they are not cheap. The aftermarket CRT electronic distributor has two bushings.
Posts: 1.8K,
Visits: 306.4K
Yours (ID by DIST ASSY ID NO) only came through with the top bushing unless it was possibly modified to fit a lower bushing at some point.
Visits: 21.5K
OK, Great. Thanks to all who helped, I'll get a bushing and see how it goes.
