Visits: 497.8K
ALL HE HAS TO DO IS USE THE END THAT GOES INTO THE DISTRIBUTOR AND CUT OFF THE OTHER END, RUN A RUBBER TUBE FROM THAT TO THE CARB JUST THE SAME AS WHAT i DID ON MY CAR. NO MAJOR BENDING IVE BEEN THERE AND DONE IT, HAVE YOU ?
HE DOES NOT HAVE TO GO OUT AND TRY TO FIND A 67 FORD PART THAT IS MOST LIKELY OBSOLETE. KULTULZ (6/3/2025)
The line that CASCO WILL FIT.; It is made specifically for a 57 distributor and says so in their catalog, despite what the other poster said. . I bought the same line and used it in the 57 distributor that I have in my 56 Bird. Yours is with an ECZ-B intake and HOLLEY with vacuum port iN the same position as the OEM? That tube was formed for a 57 312 w a 1957/59 DUAL ADV DIS w/ a 1957 OEM H4150 and ECZ-B INTAKE and will also fit a 1955 292 H2140 with a DUAL ADVANCE DIST retrofit? Wonder how many times he will have to re-bend and modify? They are fancy, one fits all. The OP has not decided yet if he is going to later fuel induction.
Posts: 1.8K,
Visits: 306.3K
Paul, I understand you are a little high strung but you might want to calm down just a bit. Your heart you know. That nipple I showed is most likely available at any large NAPA store. Now why would one buy a made-up line ($$$) to cut? I don't see your reasoning. And you also said it would fit but then said to cut it. Which is it? IVE BEEN THERE AND DONE IT, HAVE YOU ? No. I never had the money to waste like that.
Visits: 497.8K
no major bending (your snide remark). all that has to be done is cut off the carb end (will not work with the modified teapot) and run a rubber hose to the carb which can be very short. I have done this it it worked out great.. Have you had any experience is doing this modification ? I have. Most likely a better way than to hunt for a 67 ford part that is most likely obsolete which may not work. KULTULZ (6/3/2025)
The line that CASCO WILL FIT.; It is made specifically for a 57 distributor and says so in their catalog, despite what the other poster said. . I bought the same line and used it in the 57 distributor that I have in my 56 Bird. Yours is with an ECZ-B intake and HOLLEY with vacuum port in the same position as the OEM? That tube was formed for a 57 312 w a 1957/59 DUAL ADV DIS w/ a 1957 OEM H4150 and ECZ-B INTAKE and will also fit a 1955 292 H2140 with a DUAL ADVANCE DIST retrofit? Wonder how many times he will have to re-bend and modify? They are fancy, one fits all. The OP has not decided yet if he is going to later fuel induction.
Posts: 1.8K,
Visits: 306.3K
21.00 for a simple nipple fitting. You must have one hell of a good job ... Np Paul, I have never seen a BIRD or worked on one. Guess I never progressed that far.
Visits: 497.8K
stupid post KULTULZ (6/3/2025)
DANIEL TINDER
Visits: 154.2K
55blacktie (5/13/2025)
I had a near perfect 57 tach-drive distributor on my 55 Tbird. I had no idea when I inherited the car, and I don't think my dad (2nd owner) knew either. I didn't discover it until I went to replace the distributor cap with a new 55 distributor cap; the 55 cap is smaller. That's when I learned that the original 55 Teapot carburetor /w divorced choke was not compatible with the 57 distributor. The car seemed to run fine, no problem idling or cruising around town or on the highway, but as soon as I put my foot in it, it would miss, and the Fordomatic wouldn't automatically downshift. That's when I contacted Gil Baumgartner (CTCI Gil's Garage) and asked for his advice. His first question was, "What do you want to do with the car?", to which I replied, "Drive it." He then recommended that I keep the 57 distributor and replace the Teapot with a modern carburetor; I did. Rather than getting an adapter for the 55 intake manifold, I bought an ECZ-B intake manifold. Not long afterwards, I discovered that the short block in my 55 was a 56 ECZ-A. At that point, I was no longer concerned about keeping the car original. BTW: A NOS ‘57 ‘F’ code dist. just popped up on eBay ($5K) When I decided to replace the 57 Tbird distributor with a CRT, I decided to sell it. I thought I could get a handsome amount for it (based on the outrageous prices I had seen on eBay). However, I ended up selling it to a fellow member of the Sacramento Valley Classic Thunderbird Club who owns a 57. Although he said that he wanted it for a spare, he could have resold it for profit. I used the proceeds to buy the CRT distributor. If my car had been a 57 instead of a 55, I would not have parted with the 57 distributor.
6 VOLTS/POS. GRD. NW INDIANA
RossL
Visits: 7.1K
paul2748 (6/3/2025)
ALL HE HAS TO DO IS USE THE END THAT GOES INTO THE DISTRIBUTOR AND CUT OFF THE OTHER END, RUN A RUBBER TUBE FROM THAT TO THE CARB JUST THE SAME AS WHAT i DID ON MY CAR. [quote]The line that CASCO WILL FIT.; It is made specifically for a 57 distributor and says so in their catalog, despite what the other poster said. . I bought the same line and used it in the 57 distributor that I have in my 56 Bird.
This worked out fine. I cut off the carb end for the 55 vacuum line and used a hose to connect to the carb. Getting the carb to idle with no vacuum signal seems to be an issue...................I will start a new thread
Posts: 1.8K,
Visits: 306.3K
I will start a new thread...
You really need to keep all of this within one thread so that any reader can follow any previous work done.
This thread continues here - http://forums.y-blocksforever.com/Topic168581.aspx
Posts: 1.8K,
Visits: 306.3K
Now that is gnarly ...
