RossL
Visits: 7.1K
55blacktie (5/13/2025)
I had a near perfect 57 tach-drive distributor on my 55 Tbird. I had no idea when I inherited the car, and I don't think my dad (2nd owner) knew either. I didn't discover it until I went to replace the distributor cap with a new 55 distributor cap; the 55 cap is smaller. That's when I learned that the original 55 Teapot carburetor /w divorced choke was not compatible with the 57 distributor. The car seemed to run fine, no problem idling or cruising around town or on the highway, but as soon as I put my foot in it, it would miss, and the Fordomatic wouldn't automatically downshift. That's when I contacted Gil Baumgartner (CTCI Gil's Garage) and asked for his advice. His first question was, "What do you want to do with the car?", to which I replied, "Drive it." He then recommended that I keep the 57 distributor and replace the Teapot with a modern carburetor; I did. Rather than getting an adapter for the 55 intake manifold, I bought an ECZ-B intake manifold. Not long afterwards, I discovered that the short block in my 55 was a 56 ECZ-A. At that point, I was no longer concerned about keeping the car original. When I decided to replace the 57 Tbird distributor with a CRT, I decided to sell it. I thought I could get a handsome amount for it (based on the outrageous prices I had seen on eBay). However, I ended up selling it to a fellow member of the Sacramento Valley Classic Thunderbird Club who owns a 57. Although he said that he wanted it for a spare, he could have resold it for profit. I used the proceeds to buy the CRT distributor. If my car had been a 57 instead of a 55, I would not have parted with the 57 distributor. Do you like the CRT? Did you do any tuning to the CRT? Do they give you different springs?
RossL
Visits: 7.1K
I installed the 57 Dist in my car. I don't have the vacuum advance connected, because I haven't modified the carb yet. Do I need a fitting in order to connect the vacuum hard line line into the distributor? I have a fuel filter fitting screwed in now, but I don't want to use this long term.
Visits: 1.8K
The CRT distributor comes with 2 black (heavy) springs, 2 silver (medium) springs, 2 gold (light) springs, an advance stop bushing, adjustable vacuum advance, an Advancement Distributor Chart, and installation instructions. Mine is still in the box. Based upon what others (including Ted Eaton) have said, I'm not aware of any reason why I shouldn't like it. If you buy one, try it out of the box before you change the springs.
Posts: 3.6K,
Visits: 497.7K
The fitting and a vacuum line are available from the TBird part suppliers. It is a compression type fitting RossL (6/2/2025)
Visits: 306.2K
If you decide to keep the H2140/H4000 (modified DIST signal) the made-up line and fittings shown @ CASCO will not fit as it is for a LOM DIST. I think you are going to be happier (and richer) with the modified H2140 and 1957 DUAL ADVANCE DIST once you get the CARB signal worked out. Maybe try it before changing fuel delivery. https://www.eatonbalancing.com/2013/03/02/modifying-the-holley-teapot-four-barrel-carb-for-late-model-distributors/You will need this fitting to run a rubber vacuum line from the DIST to the CARB - - C7AZ 12A022-A -
FORD DEARBORN
Visits: 113.4K
You can fabricate fittings for rubber vacuum hose by cutting old rigid/steel vacuum lines close to the fittings leaving enough tube to slip a vacuum hose onto. Always make sure there are no vacuum leaks either by gauge or mouth.
Posts: 3.6K,
Visits: 497.7K
The line that CASCO WILL FIT.; It is made specifically for a 57 distributor and says so in their catalog, despite what the other poster said. . I bought the same line and used it in the 57 distributor that I have in my 56 Bird. I think I used the same piece in my 534 Ford, which has a 312 and a 57 distributor.
Posts: 3.6K,
Visits: 497.7K
This is the line normally used on a 57 distributor Note the fittings. CASCO picture
Visits: 306.2K
The line that CASCO WILL FIT.; It is made specifically for a 57 distributor and says so in their catalog, despite what the other poster said. . I bought the same line and used it in the 57 distributor that I have in my 56 Bird. Yours is with an ECZ-B intake and HOLLEY with vacuum port in the same position as the OEM? That tube was formed for a 57 312 w a 1957/59 DUAL ADV DIS w/ a 1957 OEM H4150 and ECZ-B INTAKE and will also fit a 1955 292 H2140 with a DUAL ADVANCE DIST retrofit? Wonder how many times he will have to re-bend and modify? They are fancy, one fits all. The OP has not decided yet if he is going to later fuel induction.
Posts: 3.6K,
Visits: 497.7K
UNLESS THE CASCO CATALOG IS WRONG,, IT LISTS A COMPLETELY DIFFERENT LINE FOR THE DUAL QUAD . THIS IS A PIC FOR THE DUAL QUAD (FROM CASCO) VACUUM LINE.
