Visits: 7.1K
Have a 57t-bird electric wipers, looking for new fuel pump that will fit. Maybe a FE pump?
Gary Ryan San Antonio.TX.
Last Active: 6 days ago
Visits: 39.5K
I've used a 427 FE high performance fuel pump on mine for years. Shouldn't be hard to find at your local shops.
Visits: 7.1K
Thanks, that’s what I was thinking about
Posts: 1.4K,
Visits: 2.0K
Carter M6905. Mine was made in USA, but I bought it several years ago. Depending upon your carburetor, you might need a regulator.
Visits: 7.1K
Thanks, had planed on that just to be sure. Hot fuel can push the nettle and seat open. Gets hot in Texas!!
Posts: 1.4K,
Visits: 2.0K
If you're eliminating the original double-action fuel pump, you'll need to replace the vacuum heater-control valve with a manual valve. I purchased mine from one of the Tbird suppliers (probably Concours or Casco), but you might be able to get one from your local parts store; they're universal, not vehicle-specific. Buying one locally probably will be cheaper.
Visits: 7.1K
thanks, good info
