Hydraulic clutch slave cylinder mount on y-block
Posted By Carefree Charlie Last Year
Carefree Charlie
Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)
Posts: 31, Visits: 22.8K
I have a 40 Ford coupe in which I am installing a y-block with a T5. I have installed a T5 in a 55TB and a 56 Customline and used the original mechanical Z-bar clutch linkage. The original clutch linkage in the 40 is not an option. I have decided to use a hydraulic clutch. I have the master mounted and am looking for slave cylinder to drive the clutch fork. Lots of cylinders out there but I have been unable to find anything definitive for a mount for a slave cylinder. Any suggestions or do I need to start building some cardboard mounts to see what will fit and is within my fabrication capabilities?
famdoc3
Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)
Posts: 178, Visits: 21.8K
I used truck bell housing and the slave cylinder from the truck all stock and easy to do, In my model A hot rod. Works like a charm. Got the slave from Rock Auto the flange on it bolts to the back of the block easy piezy.
Carefree Charlie
Good idea. I should have thought of it before I modified my bell housing for the T5 adapter.
I suggest a hydraulic throwout bearing.
Carefree Charlie
That wasn't my first choice but I bought one for a T5, tried to fit it and could not get the required clearance. It was to long. Probably others to try but I prefer the external anyway so after the one try have started to look for external alternatives.
