B4AE block
Posted By darrell 2 Years Ago
Posted 2 Years Ago
Last Active: 18 minutes ago
Posts: 2.0K, Visits: 306.6K
The CASTING ID NO location indicates a CLV BLOCK.
The CASTING ID DATE CODE can narrow it down further.
Posted 2 Years Ago
Posts: 3.7K, Visits: 498.2K
Ted - the question was on a B4AE block ( see pic), not on a C4AE.  Seems to be a 239 block.  This seems to be a big mystery that no one has seen before
Ted (11/10/2024)
No particular information on my end regarding the C4AE-A designation on the block.  Likely a service block and being from a truck, a replacement for an original engine.  A date code from the block would help to nail down the exact year the block was actually cast and suspect it was in the 1957/1958 era.  That was the period of time Ford was switching over the casting number nomenclature from the old system to the new.
Posted 2 Years Ago
Paul.  Good catch on catching what was a typo on my part.  I did mean B4AE and have gone back and corrected that.  The rest of the statement still stands.  There's a good chance that engine is a 239 but it will take a tear down in which to verify as the 256 engines shared the same bore size.
Posted 2 Years Ago
Which makes me think that the block is a later SERVICE REPLACEMENT for the CLV 239/256 as was the B5AE for the 272 (later service replacement).
This block was most likely the first one noticed.
Need the CASTING ID DATE CODE
darrell
Posted 2 Years Ago
Posts: 457, Visits: 22.3K
same crank ted not bore size
Posted 2 Years Ago
darrell (11/11/2024)
same crank ted, not bore size
Wish I could say I was testing you, but you are right.  The 256 and 272 engines shared the same block while the 239 and 256 engines shared the same crankshaft.  A bit of brain fade here on my part.  Thanks for the catch.
Posted 2 Years Ago
Another variation - B7ME
http://forums.y-blocksforever.com/uploads/images/9dfd9ab1-4f01-4b1c-8522-3d9f.jpg
