Balky OD solenoid when cold
Posted By DANIEL TINDER 2 Years Ago
DANIEL TINDER
Posted 2 Years Ago
Last Active: 12 minutes ago
Posts: 1.8K, Visits: 154.6K
This issue was discussed a couple years ago.  Rather than disassemble/clean, I just installed my backup unit (and a new trans. seal).  Now the backup is doing it.
I just wonder, what would happen if I stuck the spray nossel of a can of electronic cleaner into the solenoid drain hole (and sealed around the tube), filled the solenoid, let it soak a while, and then drain (?).
6 VOLTS/POS. GRD. NW INDIANA
Posted 2 Years Ago
If there’s a way for trans oil (90wt) to get on the solenoid internals it’s a possibility it could make it sticky especially if cold. The outer coil, if good, will continue to try to move the armature but the oil if there is any will make it stick. If you can take it off and clean it you will see any oil/dirt residue. Good luck.
DANIEL TINDER
Posted 2 Years Ago
Right. Just looking for a simpler fix, to maybe avoid the effort/mess.  Guess I should bite the bullet and finally clean/install the original part.  The backup unit is working intermittently, even with everything thoroughly warmed up.
I'll also try Ted’s double-seal trick while I’m at it, though I’m not seeing any lube dripping from the solenoid now.
DANIEL TINDER
Posted 2 Years Ago
Go figure.  Overdrive worked perfectly all day yesterday.  If the solenoid IS ‘gummed up’ with accumulated lube, enough use must eventually loosen everything up (?).  Likely doesn’t help either that the original 6V system is strained by running at night with the brights on, on a cold night after the car was sitting for months.
DANIEL TINDER
Posted 2 Months Ago
Go figure. I was recently reminded of the Product Service Letter advising additional wiring installation for 6V OD cars.  I ignored it as my OD typically worked ok.  Likely would have boosted current enough to overcome the occasional sticking.
lazylnm
Posted 2 Months Ago
Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)Supercharged (100 reputation)
Posts: 38, Visits: 621
Can you elaborate on the Service Letter recommendations?
Mike
'55 Glasstop 6v OD
DANIEL TINDER
Posted 2 Months Ago
Sorry, lost track of my copy.  I’m sure CASCO likely still sells it.  If I remember, it just involves doubling (?) the circuitry/wires from the ignition switch to the solenoid, and converting the bullet connections there to double adapters, thus reducing the circuit resistance.
lazylnm
Posted 2 Months Ago
Thanks for the lead.  I didn't find anything in their on-line catalogue, but I'll give them a call.  Just more added knowledge on my part.
DANIEL TINDER
Posted 2 Months Ago
Try: Accessories/Literature..2nd page
Posted 2 Months Ago
Posts: 2.0K, Visits: 306.6K
