Fuel pump question
Posted By DryLakesRacer 2 Years Ago
Posted 2 Years Ago
I have a USA rebuilt made in America double action Y block fuel pump I am preparing to install. I do not use the upper section for the windshield wiper motor and that section has a vented hose between the steel tubes.
My question whether or not you need the body breather hole when you have a PCV system installed. I believe the hole goes into the section where the arm to the actuator on the camshaft is and technically the internal crankcase which would be a suction leak to the system. What are your thoughts.
 I ask because none of the 70-80’s mechanical pumps I’ve installed on other engines don’t  have a breather hole.
Posted 2 Years Ago
Posts: 2.0K, Visits: 306.6K
That hole on the fuel pump body is a vent.
