Visits: 385
Has anyone used a proportioning valve from LEED'S BRAKES for a dual master cylinder in 1955 ford w/ all drum brakes. The proportioning valve #PVC - B. It is made for all manual drum brakes. It is universal.
Visits: 498.2K
Do you need a proportioning valve with all drums ?
Visits: 385
IYou can regulate the back brakes much better.
Posts: 2.0K,
Visits: 306.6K
An ADJ PPV (which it is not) is meant mainly for a DISC/DRUM SWAP. It would only be used (if needed) on four wheel drum where one has used different year/model wheel end brakes from different vehicles to try and balance the system. If you are adding a dual rsvr MC to a four wheel drum car with OEM wheel ends, there is no need or benefit (IMO). https://leedbrakes.com/i-19296667-adjustable-proportioning-valve-and-distribution-block-black.html
