Brakes
http://forums.y-blocksforever.com/Topic166823.aspx
By Bobby O 55 - 2 Years Ago
        Has anyone used a proportioning valve from LEED'S BRAKES for a dual master cylinder in 1955 ford w/ all drum brakes. The proportioning valve #PVC - B. It is made for all manual drum brakes. It is universal.
By paul2748 - 2 Years Ago
Do you need a proportioning valve with all drums ?
        IYou can regulate the back brakes much better.
By KULTULZ - 2 Years Ago
An ADJ PPV (which it is not) is meant mainly for a DISC/DRUM SWAP.
It would only be used (if needed) on four wheel drum where one has used different year/model wheel end brakes from different vehicles to try and balance the system.
If you are adding a dual rsvr MC to a four wheel drum car with OEM wheel ends, there is no need or benefit (IMO).
https://leedbrakes.com/i-19296667-adjustable-proportioning-valve-and-distribution-block-black.html
