Posts: 3.8K,
Visits: 33.3K
Any Front End Alignment Experts out there? I have Radials on my 56. A retired Mechanic was telling me that with Radials front End Alignment Specs should be modified for better handling especially when cornering. Right now mine was aligned to original Specs. Any suggestions on Specs. Especially Camber which would make the most Difference. Thanks
Visits: 39.4K
On the same subject is there any software that will convert the old alignment specs in inches to the degrees that the machines now use?
Posts: 1.9K,
Visits: 195.0K
I was around when radial started taking over the replacement market. But you can qualify this as an “old wives tale”. More caster so the car tracks straight, because they steer easier. I’m not sure that’s really true when you’re parking, but it was on my roadster at low speeds when I went from the bias plies to radial bias “look alike’s”. The softer sidewalls were more forgiving camber change without losing tread life.
The go to guy around here was an old alignment guy who still did a lot of hot rods and motorhomes. He knew what he could do from long experience. Maybe a local shop would be able to refer you. That’s how I found him.
Posts: 3.8K,
Visits: 33.3K
MoonShadow (7/24/2024)
On the same subject is there any software that will convert the old alignment specs in inches to the degrees that the machines now use? When I found Specs online the Camber and Caster were listed in Degrees. The Toe-in is in inches. Does that Info not work with new Alignment Machines?
Visits: 39.4K
What I get around here from the "modern" shops is that they can't align my 56 Victoria because of the changes in the machines to read degrees and they don't have the information in their computers. There may be one shop around that still has an older machine but I have only heard about it. Can you post a link to the data you found?
mjs
Visits: 123.9K
Is this what you're looking for? It should be readily available in any system.
Mine is set to stock specs with 75 series tires and 6” wide rims. There is no abnormal wear or handling.
Visits: 498.2K
For what it is worth, a guy I trust who restores TBirds (same front end as your 56) recommended the following:
Caster 3/4 to 1 degree positive Camber 3/4 to 1 degree positive Toe In slightly toed in
Visits: 39.4K
I'll check with my guy. He may not know he has it. Would be great. I've replaced all of the front end bushings and never had an alignment done. Car tracks straight and tire wear is pretty good but a little on the inside edge after many years.
stuey
Last Active: 9 Months Ago
Visits: 3.8K
Hi I know sweet fa about alignment but I need to learn as I have messed a lot with my truck running gear. How does checking temperature across the tyres with a reatively cheap infra red thermometer fit into caster/camber and toe in? stuey
