Visits: 9.3K
I had not planned go remove, the car starts extremely well. I see there is a bolt in the tube on the driver's side so thought zi would prepare the spare to be correct. I am only assuming the tube is rusted out so hopefully it will come out--masybe have to drill?
Last Active: 4 hours ago
Posts: 2.0K,
Visits: 306.6K
You have a 56 FORD and you are putting a 1957 ECZ-B intake on it? Each year intake choke system is unique. What carb are you planning on using? Are using with the 1955/56 BIRD ACL ASSY? Parts to restore the crossover tube are readily available - https://www.classictbird.com/Carburetor/products/55/1/0
