Marine Mercruiser 292
Posted By mongo Last Year
mongo
Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)
Last Active: 7 Months Ago
Posts: 224, Visits: 556
Is there any better parts on a marine 292 late 50's  has 5752 heads , just sold side draft carb and intake .
Po ol Davie
Sparta , Tn.
Cliff
Last Active: 40 minutes ago
Posts: 879, Visits: 13.5K
How much for the oil pan and timing cover?
Blind Willie
Supercharged (135 reputation)Supercharged (135 reputation)Supercharged (135 reputation)Supercharged (135 reputation)Supercharged (135 reputation)Supercharged (135 reputation)Supercharged (135 reputation)Supercharged (135 reputation)Supercharged (135 reputation)
Posts: 45, Visits: 23.8K
I have a 272 Marine block complete out of a 1960ish Higgins boat.  I have not done anything with it yet but it's not seized.   Block code is ECG DIF near the distributor, translates as a 272 from '55-'57.  It does have ECZ-G heads and aluminum Glenwood exhaust manifolds.   This appears to be a normal rotation engine with a "Capitol" reverse gear on the back.   But it has none of the other cool Interceptor stuff like an aluminum oil pan or timing cover.http://forums.y-blocksforever.com/uploads/images/359ceaf6-bfe4-42ac-81bc-1ef.jpeg
2721955meteor
Posts: 927, Visits: 190.0K
what rotation, in canada most started ,1left 1 right. sales wher poor so single engines sold, so 1 could get a counter rotation as a single engine  boat. in my experience the counter rotation along with side draft dual cards was  a disaster. cure was change to clockwise rotation
deposit the Sid draft set up in the ocean.get a 57 4v manifold and Holley carb
Blind Willie
Confirmed this is normal rotation as expected with the reverse gear trans on the back.   I pulled the fuel pump off and saw a nice clean timing chain.   A reverse rotation engine would have gear wheels.
