By mongo - Last Year
Is there any better parts on a marine 292 late 50's has 5752 heads , just sold side draft carb and intake .
By Cliff - Last Year
How much for the oil pan and timing cover?
By Blind Willie - Last Year
I have a 272 Marine block complete out of a 1960ish Higgins boat. I have not done anything with it yet but it's not seized. Block code is ECG DIF near the distributor, translates as a 272 from '55-'57. It does have ECZ-G heads and aluminum Glenwood exhaust manifolds. This appears to be a normal rotation engine with a "Capitol" reverse gear on the back. But it has none of the other cool Interceptor stuff like an aluminum oil pan or timing cover.
By 2721955meteor - Last Year
what rotation, in canada most started ,1left 1 right. sales wher poor so single engines sold, so 1 could get a counter rotation as a single engine boat. in my experience the counter rotation along with side draft dual cards was a disaster. cure was change to clockwise rotation deposit the Sid draft set up in the ocean.get a 57 4v manifold and Holley carb
Confirmed this is normal rotation as expected with the reverse gear trans on the back. I pulled the fuel pump off and saw a nice clean timing chain. A reverse rotation engine would have gear wheels.
