Visits: 22.6K
Here is how Ted and I solved the problem on the 2018 303Y for EMC. Iron head rule, 1.6 Harland Sharp roller rocker arms, Smith Brothers push rods, etc. Joe-JDC
Posts: 1.8K,
Visits: 306.3K
charliemccraney (11/20/2023)
Here's a link to Ted's article ... There 'ya go. Just like PREGO, it's in there.
Visits: 154.2K
DANIEL TINDER (11/20/2023)
“The High Side” (?). Does that that mean longer valve stems, or longer pushrods? (sorry if I’m a bit slow on the uptake). That means to err on the side of having the stand positioned slightly higher than ideal. Right. I was confusing ‘rocker’ geometry with ‘adjuster-ball/PR-cup’ geometry. Mostly a wear, rather than performance issue (?).
6 VOLTS/POS. GRD. NW INDIANA
Rocker geometry is both a wear issue and performance issue. Poor geometry increases wear and decreases lift.
Visits: 154.2K
Funny how the mind plays tricks. My comment was based on a memory re: a (supposed) tech article from years back that dealt with increased adj. ball/cup wear due to setting the adjuster/PR length for max. rocker ratio, but a thorough search of all my accumulated literature proved fruitless. So, must be a figment of my imagination. Search did point out though how complicated are the complex myriad of factors involved re: the compromises between perfect geometry/min. wear, and power range (as Ted’s single comment re: sacrificing guide wear demonstrates). BTW: Re: the OP’s original question: I noticed a tech comment (while searching) that stated increasing cam lift typically requires milling (not shimming) the stands (likely in relation to otherwise OEM setup).
