Last Active: 6 days ago
Visits: 32.6K
I just installed a Mechanical Oil Pressure Gauge in my 56. Showing 40 Psi Hot Idle. 50-55 Psi 50-60 MPH. Does this seem realistic? I would have thought Idle Pressure would be 20-25. Quality Stewart-Warner Oil Pressure Gauge.
Visits: 154.2K
Fresh rebuild? (tight/precise clearances). Too-high viscosity? Altered/high-flow pump? Really ‘Hot’ idle? (just warmed up, or after a long/hard summer drive?).
6 VOLTS/POS. GRD. NW INDIANA
Visits: 32.6K
High mileage 292. 15w40. Went for a 15 Minute Drive to try it out. Pressure dropped a little but not much. Not complaining just wondered if this seems realistic. When I had Motor partially dis-assemble couple of Years ago Crank looked good. Original Ford Bearings. Original Oil Pump.
Posts: 1.9K,
Visits: 194.9K
Typical, no. Realistic, yes.
Sounds like you’ve lucked into the rare version of a y block. One that’s been properly maintained and has had regular oil changes. Tough engines if they were taken care of.
Visits: 14.3K
Using Lucas 15w-40 I get around 15 psi at idle and 60- 70 at highway speed. My engine has around 3-4000 miles on a rebuild.
Durham Missouri
Visits: 154.2K
oldcarmark (8/10/2023)
High mileage 292. 15w40. Went for a 15 Minute Drive to try it out. Pressure dropped a little but not much. Not complaining just wondered if this seems realistic. When I had Motor partially dis-assemble couple of Years ago Crank looked good. Original Ford Bearings. Original Oil Pump. Assuming your gauge is functioning properly (?) seems like you could get away with using 10W-30 (quicker lubrication when cold, and better cooling of critical components when hot). Still plenty of common oil options in that weight that insure adequate protection of OEM flat-tappet valve gear. Just guessing, but better lube circulation might also be less likely to eventually sludge-up the head passages (dreaded Y-Block Curse)?
Visits: 137.8K
Sounds fine to me.
After an oil pump change mine read above 60 all the time and I was concerned. Since it was already installed and a PITA to change and I was reluctant to cut the bypass spring I decided to add washers to the spring nut which is external. I bought an assortment of copper washers and even tried a new Honda oil pan plug gasket which was the right diameter. I remember trying 4-5 different combinations and about .110” lowered it to 50 and that was ok by me. I still feel safe with the threads in the spring retainer nut. If it matters I use Lucas 10-30 Hot Rod oil….
