Last Active: 8 minutes ago
Visits: 38.8K
I either need a 9 tooth pinion gear or a complete set of 4:10 gears for my 56 Fairlane rear end.
Last Active: Today @ 12:18:34 AM
Posts: 1.3K,
Visits: 1.9K
If you replace only the pinion gear, there's a good chance that it will be noisy. You should look for a good, matched set of ring & pinion gears.
Visits: 38.8K
I know. I thought I had a set but the pinion turned out to be for a 9N tractor. Didn't quite fit. I want to set up a 4:10 chuck for racing so a little noise would be ok. Just thought I'd see what people have in their collection of spares.
alanfreeman
Visits: 5.7K
I have a complete 4:10 "pumpkin" out of a '54 Tudor Sedan but I think that it is the same as '56. You can have it for $50.00 + shipping. I am in SoCal.
Deyomatic
Visits: 2.5K
Would a 3.89 work for you? I THINK I still have one out of my old '55 Club Sedan...it's on the other side of NH, though and I'm down in CT. IF I still have it, I remember having had an issue with the pinion seal and it not ever sealing again. I ended up getting a highway geared pumpkin, instead. It's taking up space, again...IF I still have it.
Visits: 38.8K
alanfreeman (7/19/2023) I have a complete 4:10 "pumpkin" out of a '54 Tudor Sedan but I think that it is the same as '56. You can have it for $50.00 + shipping. I am in SoCal.Sounds interesting. Let me do a bit of checking. Where in Ca.?
Visits: 38.8K
Deyomatic (7/19/2023) Would a 3.89 work for you? I THINK I still have one out of my old '55 Club Sedan...it's on the other side of NH, though and I'm down in CT. IF I still have it, I remember having had an issue with the pinion seal and it not ever sealing again. I ended up getting a highway geared pumpkin, instead. It's taking up space, again...IF I still have it. Thanks but I have a 3:73 now and that wouldn't be much different. Appreciate the offer though.
alanfreeman
Visits: 5.7K
I am in Santa Paula about 75 miles north of L.A.
hjh
Visits: 10.6K
Chuck I have a Dana rear from a 1956 Merc 4.09 ratio it had OD had under 50,000 miles call me five-one3-60seven- 2828 if I can`t answer phone please leave message I will return your call $75 Harry Don`t what ever you do mix ring and pinion.
Posts: 1.3K,
Visits: 1.9K
If the 56 Fairlane rearend is original, it has a banjo-type (pumpkin) differential. The Dana 44 differential is integral; they don't interchange.
