By MoonShadow - 3 Years Ago
I either need a 9 tooth pinion gear or a complete set of 4:10 gears for my 56 Fairlane rear end.
By 55blacktie - 3 Years Ago
If you replace only the pinion gear, there's a good chance that it will be noisy. You should look for a good, matched set of ring & pinion gears.
I know. I thought I had a set but the pinion turned out to be for a 9N tractor. Didn't quite fit. I want to set up a 4:10 chuck for racing so a little noise would be ok. Just thought I'd see what people have in their collection of spares.
By alanfreeman - 3 Years Ago
I have a complete 4:10 "pumpkin" out of a '54 Tudor Sedan but I think that it is the same as '56. You can have it for $50.00 + shipping. I am in SoCal.
By Deyomatic - 3 Years Ago
Would a 3.89 work for you? I THINK I still have one out of my old '55 Club Sedan...it's on the other side of NH, though and I'm down in CT. IF I still have it, I remember having had an issue with the pinion seal and it not ever sealing again. I ended up getting a highway geared pumpkin, instead. It's taking up space, again...IF I still have it.
alanfreeman (7/19/2023) I have a complete 4:10 "pumpkin" out of a '54 Tudor Sedan but I think that it is the same as '56. You can have it for $50.00 + shipping. I am in SoCal. Sounds interesting. Let me do a bit of checking. Where in Ca.?
Deyomatic (7/19/2023) Would a 3.89 work for you? I THINK I still have one out of my old '55 Club Sedan...it's on the other side of NH, though and I'm down in CT. IF I still have it, I remember having had an issue with the pinion seal and it not ever sealing again. I ended up getting a highway geared pumpkin, instead. It's taking up space, again...IF I still have it. Thanks but I have a 3:73 now and that wouldn't be much different. Appreciate the offer though.
I am in Santa Paula about 75 miles north of L.A.
By hjh - 3 Years Ago
Chuck I have a Dana rear from a 1956 Merc 4.09 ratio it had OD had under 50,000 miles call me five-one3-60seven- 2828 if I can`t answer phone please leave message I will return your call $75 Harry Don`t what ever you do mix ring and pinion.
If the 56 Fairlane rearend is original, it has a banjo-type (pumpkin) differential. The Dana 44 differential is integral; they don't interchange.
That's a complete hub to hub rear end Harry?
Harry is that a complete rear end hub to hub?
