Flywheel for 11" clutch wanted
Posted By Marc 3 Years Ago
Marc
Posted 3 Years Ago
Last Active: 5 days ago
Posts: 185, Visits: 5.5K
Looking for a 11" flywheel in north or central Texas.
Marc
Posted 3 Years Ago
Should've titled this "Flywheel wanted".
Fingers got ahead of the brain.
geo56
Posted 3 Years Ago
Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)
Last Active: 7 hours ago
Posts: 162, Visits: 7.5K
I parted out a 59 Mercury years ago that was a 312 3 speed manual with the extremely long tailshaft. I tried to use this setup on my 56 victoria. I could not push hard enough on the clutch pedal to disengage. Pulled it all off and scrounged for correct Ford parts and bought a flywheel from Norbert Doll. I would like to get rid of the Mercury stuff if it would work for you. I just measured the clutch disc from the Mercury and it was 10 1/2 inches OD. I am in Tulsa  George      Would take $ 100 for all. The trans seems to have fine splines and is not overdrive.
Posted 3 Years Ago
Last Active: 14 hours ago
Fixed the title.
I have a stack of Y flywheels here so putting hands on an 11” version should not be a problem.  I’m in Central Texas.  $50 each including sales tax.
My contact info can be found at
www.eatonbalancing.com  .
cos
Posted 3 Years Ago
Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)
Last Active: 13 hours ago
Posts: 204, Visits: 119.8K
Hello  If you find one and it needs new ring gear, read post in tech section. PITA problem.
Marc
Posted 3 Years Ago
Ted I'd be happy to take one of those off your hands. I'll give you a call later today.
