By Marc - 3 Years Ago
Looking for a 11" flywheel in north or central Texas.
Should've titled this "Flywheel wanted". Fingers got ahead of the brain.
By geo56 - 3 Years Ago
I parted out a 59 Mercury years ago that was a 312 3 speed manual with the extremely long tailshaft. I tried to use this setup on my 56 victoria. I could not push hard enough on the clutch pedal to disengage. Pulled it all off and scrounged for correct Ford parts and bought a flywheel from Norbert Doll. I would like to get rid of the Mercury stuff if it would work for you. I just measured the clutch disc from the Mercury and it was 10 1/2 inches OD. I am in Tulsa George Would take $ 100 for all. The trans seems to have fine splines and is not overdrive.
By Ted - 3 Years Ago
Fixed the title. I have a stack of Y flywheels here so putting hands on an 11” version should not be a problem. I’m in Central Texas. $50 each including sales tax.
My contact info can be found at www.eatonbalancing.com .
By cos - 3 Years Ago
Hello If you find one and it needs new ring gear, read post in tech section. PITA problem.
Ted I'd be happy to take one of those off your hands. I'll give you a call later today.
