For Sale New Stock C4 replacement cam
Posted By cos 3 Years Ago
cos
Posted 3 Years Ago
Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)
Last Active: 11 hours ago
Posts: 198, Visits: 119.6K
Hello Members    Have a new stock C4 replacement cam for sale.  It was in a rebuilt engine that came with a car I bought that was never started.. If interested I can  text pics.!25. plus freight. 9 lbs from 97424.  Cos  541 221 7941 pst
Posted 3 Years Ago
Posts: 7.5K, Visits: 205.9K
When you say C4 camshaft, are you referring to 1964?
cos
Posted 3 Years Ago
Yes  It has c4 ?? 6250 ? on end of journal 5. Thanks   Also, has drilled center journal oil holes.
Posted 3 Years Ago
Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)
Last Active: Today @ 12:18:34 AM
Posts: 1.3K, Visits: 1.9K
6250 is the designation number for Ford cams. It doesn't provide duration, lift, or even application. More information is needed. Is there a number that follows "6250"?
cos
Posted 3 Years Ago
Hi Don't have any info on lift or duration. It is a  FORD replace cam, according to too  ford parts manual. Probably same grind as the one JM sells.
Posted 3 Years Ago
According to an article by J. Mummert some years ago, the post 1957 Ford std cam is basically a 1955 grind or close to a truck cam.   I doubt that he sells that grind. The mildest Cam that might be suggested, might be a  1957 copy,  It's available thru Oregon Cams, in Vancouver Washington..
John Mummert
Posted 3 Years Ago
Posts: 918, Visits: 7.5K
That is a replacement 64 truck cam. Cross-drilled oiling. All of them I have seen had CAB-X cast into the core
behind the front bearing journal. 196° @ .050" lift.  approx. .260" lobe lift
http://ford-y-block.com
cos
Posted 3 Years Ago
Thanks for dimensions  John .   Cam still for sale but a 100 plus shipping now. Cos
