Visits: 2.9K
hi all,, i have a rebuilt Y 292 that vibrates through the car at about 30-50 MPH. all the usual machining was done including line honing the block and crank and cam would spin well by hand. rods and pistons facing right way ,, changed the balancer again, static balance on flywheel and pressure plate, pulled gearbox apart and replaced all internals ,,, no difference. it does this in the shed and foot on the clutch or off makes no difference. to cut a long story short i am wondering if there is the remotest chance that by putting the cam counter weight in ( which it did'nt have ) have i created a vibe?? i would'nt think so but this problem has got me stumped. any thoughts are welcome. no pics because nothing to see. yes i have a new water pump
Last Active: 4 days ago
Posts: 7.5K,
Visits: 205.8K
Last Active: 14 minutes ago
Visits: 335.0K
Is this a high pitch buzz or low pitch knock ? Does it change pitch at different RPM ? Does this vibration change depending on what gear you are in ? Do you have an RPM gauge ? Clutch/flywheel is biggest possibility if it is RPM dependent, others are the piston assembly, one or two could be very different weight also to a smaller degree if a couple of rockers are a different ratio, and, the cam weight less noticeable. Accessories attached or not ? If it is NOT RPM dependent then it is not from the engine and something in the suspension or drive-line.
1936 Ford 3W Coupe : 56 T-Bird 312, 47 Packard 3 speed, 40 juice brakes. 1968 Merc Cyclone FB GT 390, Getting a better front clip! 1977 Ford F-250 Supercab RWD Explorer Long box. 1976 Chev Camaro RS LT Future rebuild : 1949 Ford F-1
Visits: 1.8K
If it does it "in the shed", I don't think you're going 35-50 mph, so it must not be road speed that induces vibration.
Visits: 2.9K
in the shed means at a stand still and 30-50 out on the road is the same result at approx same revs.
Visits: 2.9K
pretty sure it is revs related as at idle speed it is smooth ,when going through the rev range it vibrates like an out of balance harmonic balancer ,, but that has been changed.
Visits: 2.9K
thanks Ted for the thoughts. today after staring at the piece of junk for a while i put the new water pump ( it was hard to mount) in the lathe and spun it so the shaft was turning as in motion. after putting the dial gauge on it the shaft runs true , but the hub for mounting the fan to had 28 thou run out! i have now trued it up but am still concerned it may not be the problem. i had this same problem on a water pump may years ago . i might get lucky. tomorrow i am removing the cam and look for anything i can see.
Posts: 7.5K,
Visits: 205.8K
Simply running the engine with the belts off will rule out the possibility of the water pump and other belt driven accessories being the source of the vibration.
Visits: 2.9K
just done that
Visits: 4.5K
Update on vibration?
South Australia
