Visits: 1.8K
I've probably read as many opinions about this as to which is the best motor oil to use; however, I'm still on the fence. My better judgment tells me to use an oil-filled coil mounted horizontally in the original location on the manifold of my 55 Tbird.
Visits: 22.0K
I think oil filled coils tend to leak if mounted horizontally. If you have to mount it that way use an epoxy filled coil. JMO
Visits: 112.0K
X2, epoxy filled coils also handle vibration better.
