Oil-filled vs Epoxy-filled Coil
http://forums.y-blocksforever.com/Topic164382.aspx
By 55blacktie - 2 Years Ago
I've probably read as many opinions about this as to which is the best motor oil to use; however, I'm still on the fence. My better judgment tells me to use an oil-filled coil mounted horizontally in the original location on the manifold of my 55 Tbird.
By Dobie - 2 Years Ago
I think oil filled coils tend to leak if mounted horizontally. If you have to mount it that way use an epoxy filled coil. JMO
By 57RancheroJim - 2 Years Ago
X2, epoxy filled coils also handle vibration better.
