Baby Bird Valve cover questions.
Posted By Melly 3 Years Ago
Melly
Question Posted 3 Years Ago
Posts: 201, Visits: 48.3K
Best Replacement gasket to use on Baby Bird Aluminum valve covers. And best method to make sure they seal properly.
Posted 3 Years Ago
Posts: 3.7K, Visits: 498.3K
I've mostly used the cork gaskets with no problems.  I use RTV on the valve cover side of then gasket mostly to hold it in place.  Other than that, nothing else.  I have those covers on my 54 and my 56 Bird
Melly
Posted 3 Years Ago
thank for the information
slumlord444
Posted 3 Years Ago
Last Active: 5 Months Ago
Posts: 1.2K, Visits: 137.8K
I always use 3M weatherstrip cement to glue the cork gasket to the valve cover and a light coat of grease on the bottom. This seals well and lets you remove and replace the valve cover several times without having to replace the gasket.
Posted 3 Years Ago
I just replaced mine a week ago. I use Permatex #2 on the rocker cover, let it sit 5-10 minutes, then set on the cork style gaskets. By the look of them the original engine assembler 11 years ago did the same thing.
Posted 3 Years Ago
Last Active: 10 minutes ago
I do similar as Slumlord does.  For the aluminum valve covers, I use the thicker cork gaskets with 3M cement used sparingly on the cover itself to stick the gasket and white grease on the cylinder head side of the gasket.
Melly
Posted 3 Years Ago
Thanks to all for information Great source and people!.  .
Daniel Jessup
Posted 3 Years Ago
Last Active: 12 hours ago
Posts: 2.0K, Visits: 131.2K
I guess I follow suit with the rest of the crowd, but if you want to see some pictures and a dedicated blog post to restoring and installing a set of these valve cover then go here:
https://www.hotrodreverend.com/post/1955-ford-part-111-valve-cover-restoration
Daniel Jessup
Red Lion, Pennsylvania
FORD DEARBORN
Posted 3 Years Ago
Posts: 852, Visits: 113.5K
About 8 years ago I purchased a pair of rubber/neoprene valve cover gaskets fron Mummert that still seal very well after multiple r&r.  They stay in place on the older non lettered steel valve covers with out any sealer. Not sure if they are still available?
Melly
Posted 3 Years Ago
Would there be a torque setting to use on the baby bird aluminum covers? Maybe over thinking just want to due it right. I do remember having to recheck after motor warm up.
