Baby Bird Valve cover questions.
http://forums.y-blocksforever.com/Topic164270.aspx
By Melly - 3 Years Ago
Best Replacement gasket to use on Baby Bird Aluminum valve covers. And best method to make sure they seal properly.
By paul2748 - 3 Years Ago
I've mostly used the cork gaskets with no problems.  I use RTV on the valve cover side of then gasket mostly to hold it in place.  Other than that, nothing else.  I have those covers on my 54 and my 56 Bird
thank for the information
By slumlord444 - 3 Years Ago
I always use 3M weatherstrip cement to glue the cork gasket to the valve cover and a light coat of grease on the bottom. This seals well and lets you remove and replace the valve cover several times without having to replace the gasket.
I just replaced mine a week ago. I use Permatex #2 on the rocker cover, let it sit 5-10 minutes, then set on the cork style gaskets. By the look of them the original engine assembler 11 years ago did the same thing.
By Ted - 3 Years Ago
I do similar as Slumlord does.  For the aluminum valve covers, I use the thicker cork gaskets with 3M cement used sparingly on the cover itself to stick the gasket and white grease on the cylinder head side of the gasket.
Thanks to all for information Great source and people!.  .
By Daniel Jessup - 3 Years Ago
I guess I follow suit with the rest of the crowd, but if you want to see some pictures and a dedicated blog post to restoring and installing a set of these valve cover then go here:
https://www.hotrodreverend.com/post/1955-ford-part-111-valve-cover-restoration
About 8 years ago I purchased a pair of rubber/neoprene valve cover gaskets fron Mummert that still seal very well after multiple r&r.  They stay in place on the older non lettered steel valve covers with out any sealer. Not sure if they are still available?
Would there be a torque setting to use on the baby bird aluminum covers? Maybe over thinking just want to due it right. I do remember having to recheck after motor warm up.
By 312YBlock - 3 Years Ago
I learned this from a friend of mine and it worked perfectly so I documented it.
Valve cover gaskets (Permatex Ultra Black maximum oil resistance #82180)
Use ATV Silicone sealer on valve cover side, secure gasket with duct tape. Place cover on flat surface, weight down and let dry for 24 hours. Torque to 2-2.5 foot lbs (24 to 30 inch lbs) torque to 24” lbs easier to remove
By Skyliner57 - 2 Years Ago
Ted-do you sell the thicker cork gaskets or can you suggest a source? Thanks. Harold
Note-if you see any of my posts you will quickly realize I am new to the repair side of the Y block. I have had cars with Y block's for years but mainly write a check. The forum has been great and is fun.Thanks for helping me get in.
I spent 6 months in your area in the early 70's---Ft Hood. Tx.
