Baby Bird Valve cover questions.
Posted By Melly 3 Years Ago
312YBlock
Posted 3 Years Ago
Posts: 217, Visits: 57.3K
I learned this from a friend of mine and it worked perfectly so I documented it.
Valve cover gaskets (Permatex Ultra Black maximum oil resistance #82180)
Use ATV Silicone sealer on valve cover side, secure gasket with duct tape. Place cover on flat surface, weight down and let dry for 24 hours. Torque to 2-2.5 foot lbs (24 to 30 inch lbs) torque to 24” lbs easier to remove
1955 312 T-Bird Warwick, NY
Skyliner57
Posted 2 Years Ago
Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)
Posts: 88, Visits: 9.3K
Ted-do you sell the thicker cork gaskets or can you suggest a source? Thanks. Harold
Note-if you see any of my posts you will quickly realize I am new to the repair side of the Y block. I have had cars with Y block's for years but mainly write a check. The forum has been great and is fun.Thanks for helping me get in.
I spent 6 months in your area in the early 70's---Ft Hood. Tx.
