preferred initial valve lash on a fresh rebuilt stock 292
Posted By AllenV 2 Years Ago
AllenV
Posted 2 Years Ago
Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)
Posts: 8, Visits: 177
Hi, new member here.
   I am nearing completion on a complete rebuild of my 292.  I am keeping everything as stock as practical. Focusing only on what is relevant to my question:
The block is an EDB-E casting and the heads are ECL-C.
New valves and seats have been installed as well as complete set of “stock” push rods. The push rods are Mummert’s PR-1221-HP, LONG Pushrod for 54-55 and 60-64 heads.
The cam is a new "stock" grind and the lifters are new.
Now my question:  What is the preferred setting of the valve lash for initial start up and run in?  I have seen numbers from 0.015" to 0.019". Of course, I need numbers for a cold engine.
Thank you
Allen
Corrales, New Mexico
'55 F-100, 292 y-block
Posted 2 Years Ago
Posts: 1.9K, Visits: 194.9K
Usually a cam comes with a card showing the specs and the lash settings. Best practice is usually to follow the specifications unless you know otherwise.
Joe-JDC
Posted 2 Years Ago
Posts: 772, Visits: 22.5K
You can't go wrong with .019" cold with both an iron block and heads.  Joe-JDC
Posted 2 Years Ago
Because it is a stock replacement camshaft, the 0.019” valve lash value is a good number.  With all the new parts, you can expect some settling to occur during the break-in process so be sure to check the lash again after the engine has been thoroughly warmed up.
AllenV
Posted 2 Years Ago
Thank you.  It shall be 0.019"
Allen
Posted 2 Years Ago
Posts: 1.2K, Visits: 1.8K
Ted, is .019 hot or cold?
Posted 2 Years Ago
55blacktie (3/28/2023)
For iron heads, it’s 0.019” hot.  With iron rockers, 0.020” cold usually nets 0.019” hot.
AllenV
Posted 2 Years Ago
thank you for the clarification. I will set to 0.020" cold
Allen
