preferred initial valve lash on a fresh rebuilt stock 292
Home
Keeping The Dream Alive!
Technical
http://forums.y-blocksforever.com/Topic163968.aspx
Print Topic
Close Window
By AllenV
2 Years Ago
Hi, new member here.
I am nearing completion on a complete rebuild of my 292. I am keeping everything as stock as practical. Focusing only on what is relevant to my question:
The block is an EDB-E casting and the heads are ECL-C.
New valves and seats have been installed as well as complete set of “stock” push rods. The push rods are Mummert’s PR-1221-HP, LONG Pushrod for 54-55 and 60-64 heads.
The cam is a new "stock" grind and the lifters are new.
Now my question: What is the preferred setting of the valve lash for initial start up and run in? I have seen numbers from 0.015" to 0.019". Of course, I need numbers for a cold engine.
Thank you
By miker
2 Years Ago
Usually a cam comes with a card showing the specs and the lash settings. Best practice is usually to follow the specifications unless you know otherwise.
By Joe-JDC
2 Years Ago
You can't go wrong with .019" cold with both an iron block and heads. Joe-JDC
By Ted
2 Years Ago
Because it is a stock replacement camshaft, the 0.019” valve lash value is a good number. With all the new parts, you can expect some settling to occur during the break-in process so be sure to check the lash again after the engine has been thoroughly warmed up.
By AllenV
2 Years Ago
Thank you. It shall be 0.019"
By 55blacktie
2 Years Ago
Ted, is .019 hot or cold?
By Ted
2 Years Ago
55blacktie (3/28/2023)
For iron heads, it’s 0.019” hot. With iron rockers, 0.020” cold usually nets 0.019” hot.
By AllenV
2 Years Ago
thank you for the clarification. I will set to 0.020" cold
